[bascom] problem with single variable
Discussion in 'Embedded Systems and Microcontrollers' started by king40, May 23, 2014.
  1. king40
    Jul 17, 2013
    75
    hi engineers :cool:
    i have a single variable
    like this
    dim a as single
    a=12345.12345
    and i config single with this code:
    Config Single = Scientific , Digits = 5
    when i want use of my " a " variable
    my output is
    12345.12
    i dont know why :confused:
    anybody know why ? :(
    thanks
  2. tshuck
    Oct 18, 2012
    3,531
    675
    It's because you are losing resolution with using a Single. Use a Double if you want to capture more data.
    The Single devotes less bits to the fractional portion of the floating point number, than a Double would. Your number is at the limit of what a Single can represent.
    king40 likes this.
  3. king40
    Jul 17, 2013
    75
    with double still have error
  4. tshuck
    Oct 18, 2012
    3,531
    675
    How are you verifying the value?
  5. king40
    Jul 17, 2013
    75
    Dim a as double
    A= 12345.12345
    Dim y as string*20
    Y= str (a)
    LCD y
    Output:
    E3u if i Dnt mistake
