barrel shifter
Discussion in 'Programmer's Corner' started by Infinity1, Apr 16, 2009.
  1. Infinity1
    Jan 11, 2009
    16
    Hello Everyone
    i wrote a code for a barrel shifter and it passes the compilation
    but in the simulation it gives me nothing in the output
    here is the code:
    library ieee;
    use ieee.std_logic_1164.all;
    Entity barrel_shifter is
    Generic(n: integer := 8);
    port(inp: in std_logic_vector (7 downto 0);
    shifter: in integer range 0 to 1;
    outp:eek:ut std_logic_vector (7 downto 0)
    end barrel_shifter;
    architecture behave of barrel_shifter is
    signal tmp: std_logic_vector(7 downto 0);
    begin
    process(inp,shifter)
    begin
    if (shifter = 0) then
    tmp <= inp;
    else
    tmp(0)<='0';
    for i in 1 to inp'HIGH loop --for i in 1 to 7 loop;
    tmp(i)<=inp(i-1);
    end loop;
    end if;
    end process;
    outp<=tmp;
    end behave;
    can someone explain me why it shows nothing in the simulation?
  2. DrNick
    Dec 13, 2006
    110
    what input vector are you providing to the simulation?
  3. tuborggg
    Jan 3, 2009
    37
    It won't show you anything if you won't give it something (a.k.a test-bench which simulate input).
