Bare Bones Windows Serial Program
Discussion in 'Programmer's Corner' started by Brownout, Jan 13, 2014.
  1. Brownout
    Jan 10, 2012
    2,375
    998
    I want an absolute bare bones windows serial program to use as a base to build my application. I found this code (shamelessly copied from here: http://forums.codeguru.com/showthread.php?442634-Serial-port-program-in-c-language It looks like what I need to get started. I plan to compile it using VCC 2005 and run it on a XP machine. Does anyone see any potential issues?:
    NOTE: I;m working to get this code to display better
    Code ( (Unknown Language)):
    1.
    2.
    3. [SIZE=2]#include <windows.h>[/SIZE]
    4. [SIZE=2]#include <stdio.h>[/SIZE]
    5. [SIZE=2]int main(int argc, char *argv[])[/SIZE]
    6. [SIZE=2]{[/SIZE]
    7. [SIZE=2]DCB dcb;[/SIZE]
    8. [SIZE=2]HANDLE hCom;[/SIZE]
    9. [SIZE=2]BOOL fSuccess;[/SIZE]
    10. [SIZE=2]char *pcCommPort = "COM2";[/SIZE]
    11.
    12. [SIZE=2]hCom = CreateFile( pcCommPort,[/SIZE]
    13. [SIZE=2]  GENERIC_READ | GENERIC_WRITE,[/SIZE]
    14. [SIZE=2]  0, // must be opened with exclusive-access[/SIZE]
    15. [SIZE=2]  NULL, // no security attributes[/SIZE]
    16. [SIZE=2]  OPEN_EXISTING, // must use OPEN_EXISTING[/SIZE]
    17. [SIZE=2]  0, // not overlapped I/O[/SIZE]
    18. [SIZE=2]  NULL // hTemplate must be NULL for comm devices[/SIZE]
    19. [SIZE=2]);[/SIZE]
    20. [SIZE=2]if (hCom == INVALID_HANDLE_VALUE) [/SIZE]
    21. [SIZE=2]  {[/SIZE]
    22. [SIZE=2]  // Handle the error.[/SIZE]
    23. [SIZE=2]  printf ("CreateFile failed with error %d.\n", GetLastError());[/SIZE]
    24. [SIZE=2]  return (1);[/SIZE]
    25. [SIZE=2]}[/SIZE]
    26. [SIZE=2] // Build on the current configuration, and skip setting the size[/SIZE]
    27. [SIZE=2] // of the input and output buffers with SetupComm.[/SIZE]
    28. [SIZE=2] fSuccess = GetCommState(hCom, &dcb);[/SIZE]
    29. [SIZE=2] if (!fSuccess) [/SIZE]
    30. [SIZE=2]   {[/SIZE]
    31. [SIZE=2]   // Handle the error.[/SIZE]
    32. [SIZE=2]   printf ("GetCommState failed with error %d.\n", GetLastError());[/SIZE]
    33. [SIZE=2]   return (2);[/SIZE]
    34. [SIZE=2] }[/SIZE]
    35. [SIZE=2] // Fill in DCB: 57,600 bps, 8 data bits, no parity, and 1 stop bit.[/SIZE]
    36. [SIZE=2] dcb.BaudRate = CBR_57600; // set the baud rate[/SIZE]
    37. [SIZE=2] dcb.ByteSize = 8; // data size, xmit, and rcv[/SIZE]
    38. [SIZE=2] dcb.Parity = NOPARITY; // no parity bit[/SIZE]
    39. [SIZE=2] dcb.StopBits = ONESTOPBIT; // one stop bit[/SIZE]
    40. [SIZE=2] fSuccess = SetCommState(hCom, &dcb);[/SIZE]
    41. [SIZE=2] if (!fSuccess) [/SIZE]
    42. [SIZE=2] {[/SIZE]
    43. [SIZE=2]   // Handle the error.[/SIZE]
    44. [SIZE=2]   printf ("SetCommState failed with error %d.\n", GetLastError());[/SIZE]
    45. [SIZE=2]   return (3);[/SIZE]
    46. [SIZE=2] }[/SIZE]
    47. [SIZE=2] printf ("Serial port %s successfully reconfigured.\n", pcCommPort);[/SIZE]
    48. [SIZE=2] return (0);[/SIZE]
    49. [SIZE=2]}[/SIZE]
    50.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    It looks suspiciously similar to the "Configuring a Communications Resource" article from MSDN, which means it has a little more credibility than most internet-generated code. I haven't used this method, but it seems okay.
    The only thing I would point out, and this may, or may not, seem obvious, make sure you set the correct COM port when you compile.
    Brownout likes this.
  3. Brownout
    Jan 10, 2012
    2,375
    998
    I got this code to work, but only after dynking around with it all day. I had to make a change to my VC++ configuration to use Multi Byte Character Set for the CreateFile function to work. After exhausting google looking for the answer, I posted on Jan Alexson's Lake View Project forum, and she provided links that got me going :)
    tshuck likes this.
