Hi all,
I want to use a barcode scanner to obtain the item information and the orientation of the item while being scanned.
I did some research on barcode format CODE_128 and found that it consists from a Start and Stop pattern so the system will know from where to start the pattern decoding. I was planning to achieve this by implementing a barcode pattern as shown in the attached image, where a pattern which indicates the orientation if the item is followed by a CODE_128 barcode format. How can this be achieved?
Any help would be highly appreciated.
