bandwidth filter
fred_uk
Joined Jan 3, 2009
67
so do i need to add abit more between the inductive amp and the tone detection circuit?
also
as there anything i can do to further amplify the signal on the inductive amp without adding opamps ie chance component values or anything?? forgive me im on a steep learning curve here...
thanks
fred_uk
Joined Jan 3, 2009
67
hi, me again
a question for hgmjr, looking at your design im building up a bill of materals, do the capacitors need to be polorised or non polorised, ive specified ceramic disc ones, should these be ok??
thanks
hgmjr
Joined Jan 28, 2005
9,027
hi, me again
thanks
If you can get non-polarized 1uFd. that would be ideal. The timing caps need to be 10% tolerance.
Have you come up with a circuit to use to get the 5V logic levels from the audio output.
hgmjr
fred_uk
Joined Jan 3, 2009
67
no not yet hgmjr, to be honest i hope i havent bit of more than i can chew. Although i got the inductive amplifier working so maybe with everyones help i can get the 'tone detection' part working too!
Also, i presume the circuit was designed on some software? does that software allow you to test it in a simulator? to be honest its been some years since i have used any software and things seem to of changed alot, i am hoping it will be 'easier' now to produce my own pcbs
fred_uk
Joined Jan 3, 2009
67
using an inductive amplifier to detect tones, similar to cable tracer except with a larger bandwidth,
editted to add
the operating enviroment is noisy, hence the led part of the project as headphones just wouldn't work
fred_uk
Joined Jan 3, 2009
67
i've been looking around for a circuit i been googling 'sine save to sqaure wave converter, inverter and many other combinations and cant find anything suitable
i don't think im upto this, can anyone help otherwise i will have to bin the whole idea, which is ashame as the inductor side works i just need to get this led working which is the harder part with all the filters etc...
editted to add
ive now got a bill of materials for all my components and will try and build 3 circuits less the 'coverter' part as i might be able to add this later
fred_uk
Joined Jan 3, 2009
67
would this circuit be suitable:
whats the varible resistor for? how would i calculate values of components and what ic would suitable for this application?
thanks
bertus
Joined Apr 5, 2008
22,278
The potmeter is to adjust the "switching level".
The Positive Feedback Resistor is to set the offset from the "switching level".
The Positive Feedback Resistor is most times 10 - 100 times the potmeter value.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,278
The 7805 is a 5 volt stabelizer IC like a LM7805 or MC7805.
The preamp uses 9 Volts but the digital part runs at 5 Volts.
The 311 is indeed a LM311 comparator.
The inverter is one of the leftovers from hgmjr's inverters, to shape it real squarewave.
Greetings,
Bertus
fred_uk
Joined Jan 3, 2009
67
hi everyone
i have just made some calculations for a highpass and lowpass filters
low pass filter
freq = 3khz
r1 & r2 = 10k
cap1 = 7.5nf
cap2 = 3.5nf
highpass filter
fr1 =20k
r2=10k
cap 1,2 = 22nf
what do you guys think do these figues seem ok?
thanks
fred
fred_uk
Joined Jan 3, 2009
67
i was talking about audioguru's suggestion, attached with led and high pass and low pass filters with my calculations. What do you make of this now I have put it all together..
