bandwidth filter
Discussion in 'General Electronics Chat' started by fred_uk, Feb 8, 2009.
  1. fred_uk
    Thread Starter Active Member
    Jan 3, 2009
    67
    can anyone help with the design of a bandwidth filter, i have the documentation but cant seem to work out the values, I am a newbie at this.
    the freqency is 500hz to 3000hz
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you chosen a filter circuit topology?
    hgmjr
  3. mik3
    Feb 4, 2008
    4,846
    63
    Are you interested in active filters?
    Where is the documentation?
  4. fred_uk
    Jan 3, 2009
    67
    sorry guys, i must admit i know very little about filters, other than i need a bandpass filter, from 500hz to 3000hz, i was then hopeing to use a transitor to provide a switched output on the presence of a tone within the bandwidth specified
    sorry about the lack of documentation, im a newbie at this
  5. mik3
    Feb 4, 2008
    4,846
    63
    Then you can use a band pass filter like this one here:
    http://www.captain.at/electronics/active-filter/
    Then use a comparator to compare the output of the filter with a DC voltage and when the output of the filter is greater than the DC voltage the comparator will go high.
  6. fred_uk
    Jan 3, 2009
    67
    thanks mike,
    will i be able to cover the full bandwidth (500hz to 3000hz) in which case the centre freq would be 1750hz ?? would that be correct?
  7. mik3
    Feb 4, 2008
    4,846
    63
    You if you set the bandwidth of the filter properly. However, remember that filters are not ideal they will pass frequencies near the bandwidth with a respectable amplitude.
  8. Skeebopstop
    Jan 9, 2009
    358
    Hey Mike, do you know of a site showing the derivation of the filter you posted?
    I found this one which seems easier and simpler to implement (See inverting band pass):
    http://www.electronics-tutorials.ws/filter/filter_7.html
    Perhaps it doesn't have as good an attenuation?
    One thing about your link Mike, I popped in some values and everything looked ok except R3, it calculated me a - value for resistance!? In other pages I found implementing the same filter, they just didn't have R3. Any reason it is there?
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    The ratio of (R4/R3) +1= gain of the opamp. Remove R3 then the opamp has no gain.
    This extremely simple "bandpass" filters have almost no attenuation of outside signal frequencies. They attenuate frequencies you want because its cutoff frequencies are droopy and are not sharp.
    The better filters I showed on the other website are "2nd-order" and have twice as much attenuation of outside signal frequencies as these 1st-order filters.
    3rd-order and 4th-order filters are even better.
    You asked why you can still hear 100Hz when the highpass filter is 4th-order. Of course, the attenuation is not much, you need 10th-order.
  10. leftyretro
    Nov 25, 2008
    394
    My gut says you would have better luck, more realistic component values and better circuit Q if you designed it in two stages, a lowpass active filter stage driving a highpass active filter. Most bandpass filter don't have to deal with such a wide bandpass as related to it's center frequency.
    Lefty
  11. fred_uk
    Jan 3, 2009
    67
    hi guys,
    sorry another bone question to ask...
    what chip am i using to create this filter??
  12. Skeebopstop
    Jan 9, 2009
    358
    I was referring to Mike's circuit. -R2/R1 is the gain of the inverting amp. So what the is R3 doing? I found a site which had the same bandpass inverting filter but didn't have that R3 there.
  13. Skeebopstop
    Jan 9, 2009
    358
    Can you even get 10th order in hardware? I thought that was purely a DSP thing.
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  15. fred_uk
    Jan 3, 2009
    67
    what do you guys think of this circuit, a high pass filter followed by a low pass and then a comprator circuit. All i need to do is light the led when a tone between 500hz and 3khz is detected, however my maths isnt veryy good and i could do with some help on the values of components.
    what do you think of the circuit design so far. I have been told it will need to run off two 9 volt batteries to provide a simple bi-polar power supply.
  16. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You will need to rectify afther the filters to have a DC voltage that you can compare with the DC reference.
    What type of filters do you want to use ?
    Depending on the resistor and capacitor values the filter will have different properties.
    Greetings,
    Bertus
  17. fred_uk
    Jan 3, 2009
    67
    what do you mean by what type of filters? i thought they were high pass and low pass, am i missing a bit to my comparator circuit?
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    Mike's circuit is a simple narrow-bandwidth bandpass filter.
    Your requirement has a bandwidth that is too wide for it.
    At frequencies that you want high attenuation it barely has any attenuation.
    Look it up in Google: Multiple Feedback bandpass filter Circuit
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    Your comparator compares the DC output voltage of the filter IC to the setting of the trimpot:
    Turn the pot up and the LED lights.
    Turn the pot down and the LED turns off.
    You need to rectify the output of the filter, filter the pulses with a capacitor then drive a transistor with the result. The transistor will turn on the LED when there is a signal.
    Opamps do not need a dual-polarity supply if their input is biased at half the supply voltage.
  20. fred_uk
    Jan 3, 2009
    67
    so would the one circuit you listed above be suitable to such a wide bandwidth??
    or would i need more than one centred on different frequencies
    the tones are at:
    500hz
    750hz
    1000hz
    2000hz
    3000hz
    thanks
    fred
