+/- Bandwidth definition?
perplexabot
Joined Jul 3, 2012
15
Hey all. So I been trying to buy a narrow BPF and on the datasheets it'll say something like: +/- 12.5 under 6dB bandwidth for a specific component. Here is a datasheet for reference if needed: http://pdf1.alldatasheet.com/datasheet-pdf/view/87544/ETC/CFWS455CY.html
My question is, does +/- 12.5 Bandwidth mean 25 bandwidth?
By +12.5 and -12.5 are those the pass band regions to the right and left of the center frequencies respectively?
Thank you.
bertus
Joined Apr 5, 2008
22,276
Yes, the +/- 12.5 will mean a bandwidth of 25 kHz around the center frequency.
You also see the bandwidth at 40 dB attenuation given.
This will tell you how steep the filter is.
Bertus
