Hey all
I have an issue with the response from a BPF I created, however I do not know how to approach explaining it. The issue is this;
I have a very narrow bandwidth BPF (4-7Hz - for an EEG brainwave filter), I designed it using the sallen-key topology and using a buttersworth response and its 4th order. Simulated using multisim the passband region is pretty much flat and then drops off nicely at the transition.
However in reality when breadboarded the response was much more like a bell curve, where there was a peak in gain at the centre frequency (above the gain calculated for) and the gain expected was seen much closer to the -3dB points. So in essence, my buttersworth response wasn't very 'maximally flat'
I have spent a good few days trying to find a way to explain this but haven't found very much. My thoughts are; that either there is some issue due to how small the bandwidth is, which is resulting in the fact that transitioning from the stopband to passband and visa-versa creates the curve. Or that its something more to do with the design?
However I have nothing other than assumptions to back this up, any input would be greatly appreciated
Rob
Rob
