Bandpass FIR filter using windowing and matlab
Discussion in 'Programmer's Corner' started by ElectricFlow, May 3, 2009.
  1. ElectricFlow
    May 3, 2009
    I am working on an assignment for school in DSP. I need to Design a linear phase, causal, digital Bandpass FIR filter using the windowing method that meets the following specifications with the lowest possible filter length, M:
    Sampling Freq: 24Khz
    passband p1 2pi4000 p2= 2pi8000
    stopband st1=2pi3000 st2= 2pi9000
    minimum stopoband attensuation= 40dB
    I found some Matlab code online and started altering it to my specifications. However I am not sure what i need to use for the DEV variable, or if I have the rest of it right at all. Any help would be appreciated. The code i have is shown below.
    fs=24000; % sampling rate
    F=[3000 4000 8000 9000]; % band limits
    A=[0 1 0]; % band type: 0='stop', 1='pass'
    dev=[0.0001 10^(0.1/20)-1 0.0001]; % ripple/attenuation spec
    [M,Wn,beta,typ]= kaiserord(F,A,dev,fs); % window parameters
    b=fir1(M,Wn,typ,kaiser(M+1,beta),'noscale'); % filter design
