Bandpass filters
Discussion in 'General Electronics Chat' started by kivir, Dec 17, 2008.
  1. kivir
    Dec 17, 2008
    Hello,I want to design a dual band filter.Do you think that using 2 band pass filter and connect them in parallel is a good idea to achive this goal?
    Another question about bandpass filters: Can I obtain a band pass filter without using an opamp and inductor, and how?(I think I should use transistors in my project)
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. PRS
    Aug 24, 2008
    989
    35
    What is a dual band filter? How can you possibly wipe out one band and retain it's passband after wiping it out with the last filter? What are you trying to do?
    Yes, you can use transistors to make active filters. One way is to use a FET or a BJT to drive a tank -- that is, an inductor in parallel with a capacitor. This is a winding on a toroid with a capacitor in parallel with the winding. Then, put another winding on the same toroid and you have the secondary of a transformer. The secondary drives the next stage.
    The beauty of this is that the input resistance of the next stage is reflected through the transformer windings by the square of the turns ratio. If you use 2:1 step down, then the first stage sees 4 times the input resistance of the second stage. If you wind 3:1 then the resistance seen by the first stage is 9 times greater than the resistance looking into the second stage.
    This may be a bit confusing, I know. But more if you want it.
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    Quite true if the filters are connected in series.
  6. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    64
    I'm just kicking this around, but what if you had say 4 different bandpass filters connected in parrallel, and the output of each filter would be connected to a seperate load, the signal coming in would be applied to each filter simultaneouisly, so each filter does not interact with each other OR does one filter hog most of the signal if it is lesser impedance to ground through it's load??
    But if you had 4 signals of differnet frequencies each filter would pick up it's band of frequencies much like a radio reciever as you tune it.
    Instead of having one filter the tank circuit ,you would have 4 filters.
    Like having 4 radios tuned to 4 seperate stations.
    So yeh. you could have filters in parrallel to pick up different frequencies in each of it's own bandwidth.
  7. leftyretro
    Nov 25, 2008
    394
    Yes the output of each filter would drive it's load from signals within it's bandpass. Keep in mind that paralleling the inputs changes the total input impedance of the combined filter and that would require rematching to the source driving the combined filter.
  8. hobbyist
    Aug 10, 2008
    774
    64
    Yes. Good point...
  9. KL7AJ
    Nov 4, 2008
    2,047
    295
    But of course! You can use two series circuits in parallel, or two parallel circuits in series. Or combinations of both.
    Little historical note.....this was common practice in many early A.M./F.M. radios where they used the same I.F. strip for both 10.7 MHZ and 455KHz.
    Now you know!
    Eric
  10. aloksurve
    Dec 18, 2008
    Hey Whats d application for which u are designing d dual band pass filter..??
  11. aloksurve
    Dec 18, 2008
  12. Ron H
    Apr 14, 2005
    7,050
    657
    Hi Eric,
    Not sure what you mean. Two bandpass filters in series is a "nopass".:eek:
  13. eblc1388
    Nov 28, 2008
    1,542
    102
    It is common practice in AM/FM radio that the I.F. transistor collector load consists of two I.F. transformers in series, one resonant on 455KHz and one on 10.7MHz.
    But they are not band pass filter in this context. They resonance at the IF frequency and present a load for the transistor while the other one is just a near short circuit.
  14. KL7AJ
    Nov 4, 2008
    2,047
    295
    Hi, Mr. Chung.
    This depends on the topology of the filters. Indeed, two cascaded bandpass filters, where the bandpasses don't overlap, would be a "no-pass" filter. But how about those two bandpass filters in PARALLEL? We now have two independent paths for the signals.
    Eric
  15. Ron H
    Apr 14, 2005
    7,050
    657
    No argument there. I didn't understand what you meant by
