BandPass Filter - Sallen Key
Discussion in 'Homework Help' started by ifeelhappy, Apr 5, 2011.
  1. ifeelhappy
    Dec 18, 2008
    5
    Hi everyone,
    Any one have a link of documentation to fix this problem.
    What is the step by step to calculated the component value?
    I would like to calcualted all the compoenet value (resistor and capasistor).
    Apperciated your all help.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    ifeelhappy likes this.
  3. ifeelhappy
    Dec 18, 2008
    5
    yes...but i have stuck on how to combine with low pass and the high pass...i spend whole week at this....get headache.
    Even refer the analog and the NS website also get stuck.
    Any hints for this. Thanks
    If can, can list down the step. Thanks a lot
  4. ifeelhappy
    Dec 18, 2008
    5
    Any one can help.....at least some hints
  5. ifeelhappy
    Dec 18, 2008
    5
    how to get R1 and R2??
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    There are probably at least two stages of learning which will lead you to acquiring some skill in circuit design - such as is required in this case of filter design.
    Analysis - before you can design a circuit you need to be able to analyze a circuit. What makes it work? What is happening physically? What mathematics are involved? And so forth ... For instance this is a Chebyshev filter - what does that mean? What other filter types are there?
    Synthesis - being able to analyze the design is important. Then comes the ability to create something from scratch based on what you understand about typical circuits that perform the required task. There are issues of specification. How will you meet that specification? What compromises will you make? What are the limitations of your design. And so on ...
    So let me ask you. Are you able to analyze the circuit you have posted? - if not then you are unlikely to be able to successfully design that filter for other conditions. For example - a different gain or cut-off frequency or pass-band.
    In any case, the design shown for the given specification probably wont be unique - there will be many possibilities in terms of component values for instance.
  7. Vahe
    Member
    Mar 3, 2011
    75
    9
    For the Sallen-Key topology take a look at the bottom of the following page
    http://en.wikipedia.org/wiki/Sallen–Key_topology
    From the original post, it looks like you have used Texas Instruments' Filter Pro Desktop to design your filter. You will need to study the results with the explanation of the transfer functions given the in the document above to figure things out.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
