Band stop filter
Discussion in 'General Electronics Chat' started by Jonathan Bell, Jan 4, 2008.
  1. Jonathan Bell
    Jan 4, 2008
    Why would the output voltage of a bandstop filter be higher than the supply voltage when not at resonant frequency?
    For example a bandstop filter is used where a supply of 10v is used. A resistor of 200ohms is put in series with the filter. Resonance is at 7kHZ and gives an output of 516mV. However at 1kHZ the output is 11.7V. How can this be when the source is only 10V?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you post a schematic of the circuit your are using? That would aid us in our response.
    hgmjr
  3. Jonathan Bell
    Jan 4, 2008
    The attached picture show an example of the very simple filter in use. L1 and C1 are unknown as the filter was given as an invistagation. The output voltage was taken across the load resistor. The question is why would a reading of 11.7V be taken when th source is 10V.
  4. scubasteve_911
    Dec 27, 2007
    1,202
    Wouldn't this be because the tank circuit is acting like a storage element with a voltage potential in series with a DC supply ?
    That's my guess anyways
    Steve
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Is this a simulation, or hardware? How are to measuring the source and the output?
    You must have had some actual values of L and C if you got measurements. Or is this a homework problem, and you are supposed to explain the hypothetical results?
  6. cableboy70
    Jan 11, 2008
    Not sure...maybe its because the interaction between inductor and capacitive reactance...with the present of resistive component ? (the 200ohms resistor)
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Are you certain that you have your meter set up correctly?
