band pass filters
Discussion in 'Homework Help' started by Jayeeta, Oct 28, 2007.
  1. Jayeeta
    Oct 28, 2007
    How can we create a band pass filter when two cutting values are given?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    I have moved this thread to the homework forum.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If "cutting value" means corner frequencies. then you combine a low pass filter and a high pass filter set at those value. The passband is the range of frequencies between the lower and upper corners.
  4. Management
    Sep 18, 2007
    306
    Do you know what those cutting values represent? As beenthere said, they might mean the corner frequencies of the bandpass filter which essentially are used to "cut" out all other frequencies that are to be passed. Those values are represented by this equation:
    cut freq = 1 / (2*pi*R*C)
    So you can go from there and figure out what your R and C values will be. You can check the ebook I think for circuit configuration.
  5. mozikluv
    Jan 22, 2004
    1,437
    you can also achieve your passband circuit with the use of one opamp configured as a multifeedback or use two cascaded opamps as a sallen key.
    moz
