Hi! I want to create some sort of band pass filter for my stereo setup to filter the sound to my sub woofer. I want either 100hz and below, or 80hz and below, it doesn't make much of a difference. I am wiring the sub woofer in parallel with my left and right speakers.
So my questions start here. First off I want to know if I should use a passive or active filter because I am still a beginner so I am not sure if I want to go into something such as an active filter. Also, will I need to build some sort of circuit to redirect the untouched sound to the smaller speakers because it will be wired in parallel? So what kind of circuit should I use?
Also I need some sort of mid-range and high pass filter for my stereo speakers, all I want to do is filter out the 100hz that will go to my subwoofer, because I have such a huge bass boost on that my stereo speakers sound distorted with their tiny 5" woofers.
So what kind of circuit do I need to seperate the audio at the 100hz line and send the low end one way, and the high end the other?
Thanks to all that help!!!
