Band pass filter
Discussion in 'Homework Help' started by naspek, Mar 30, 2010.
  1. naspek
    Feb 17, 2010
    45
    hey there..
    i'm trying to design a bandpass filter with pass band frequency from 10 kHz to 20 kHz and gain = 1
    however, my circuit didnt give me the correct graph.. my circuit is correct?
  2. The Electrician
    Oct 9, 2007
    2,300
    335
    You need to tell us a little more about your project.
    Your circuit appears to be a cascade of a high pass filter followed by a low pass filter.
    Usually filters are specified by more than just saying "pass band frequency from 10 kHz to 20 kHz and gain = 1".
    Is that all your problem asks for? Or have you heard phrases like "Butterworth filter", "Chebychev filter", "maximally flat), "pass band ripple", etc.
    When you say "my circuit didnt give me the correct graph", are you referring to a Bode plot of the filter response? In what way did it fail to give the "correct graph"?
    naspek likes this.
  3. naspek
    Feb 17, 2010
    45
    ok.. thanks for your reply..
    i want to design a bandpass filter with pass band frequency from 10 kHz to 20 kHz and gain = 1 . By combining a Butterworth 2nd order low pass filter and a high pass filter to obtain the bandpass filter. The roll-off rate should be at least -40dB/ decade.
    the correct graph should give me -40db/decade for the roll of rate..
    but, my graph can't achieved -3dB.. that's why i said, my graph is incorrect..
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Have you thought about using a filter design tool such as TI's FilterPro? The latter can be downloaded for free.
  5. The Electrician
    Oct 9, 2007
    2,300
    335
    Would you please post your graph? Set the frequency limits from 1 Hz to 500 kHz.
  6. naspek
    Feb 17, 2010
    45
    here is my graph.. i also attach my circuit file in the attachment..
  7. The Electrician
    Oct 9, 2007
    2,300
    335
    Have a look at the attached image.
    The blue and red plots are the responses of the individual high and low pass filters. The green plot is the overall response.
    The overall response has a 40dB/decade rolloff rate, but your pole frequencies are wrong for a Butterworth bandpass response.
    Your pole frequencies are on the negative real axis when they should be complex.
    Explain how you determined the values for your resistors and capacitors and we can see where your mistake is.
    naspek likes this.
