Baldor 2.5hp, 200VDC, 11.2A motor
Discussion in 'Marketplace' started by Andreas, Oct 12, 2015.
  1. Andreas
    Thread Starter Active Member
    Jan 26, 2009
    68
    Baldor (US made) 2.5 Horse Power, 200VDC, 11.2 Amp, electric motor, 4000rpm
    Spec 34-6701-3662G3
    Frame size 56YZ
    Encl Type TEFC
    TYPE PM3428P
    Approx. dimensions: 200 x 200 x 380 mm
    Approx Weight: 21 kg**
    This motor came off a working treadmill that had a broken drive pulley wheel on the front roller (it was only plastic so was destined to fail which was a shame for such an expensive, high end treadmill). I had always hoped to replace the pulley wheel but just never got around to it; meaning the motor hasn't done much work in its life. I have had it in storage ever since and it is fully operational. Comes complete with motor controller PCB, control panel, cables and drive belt.
    ** Due to its weight and size this is collection only from Wiltshire in the UK.
    The lot for just £120 - Bargain!
  2. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Baldor make nice DC motors, if putting it to some other use than T.M. you may want to remove the flywheel.
    From the Capacitors on the controller, it would indicate a PWM controller, rather than SCR bridge.
    Max.
