I have a power supply arrangement using two D1088 (6A. PNP Darlingtons) the bases of which are controlled by an LM317. Thus the two transistors are carrying the current, not the LM317. It works very well, giving tight regulation over widely varying load. But here's the rub: one of these two transistors runs about twice as hot as the other, which I suppose is due to normal manufacturing differences from one to the next. If I were trying to balance the two to carry about the same current, would I put a resistor in series with the base of the hotter transistor? That should restrict base current and cut the heating of that transistor. However, I don't know if there is any downside to such an arrangement.
Any thoughts would be appreciated.
