Balanced vs. Unbalanced Attenuators
Discussion in 'General Electronics Chat' started by Prodigal, Nov 11, 2006.
  1. Prodigal
    Oct 12, 2006
    10
    Hi Guys,
    Could anybody tell me what the advantages or disadvantages are in using a simple balanced 'tee' attenuator over an unbalanced one?
    Obviously the difference is that a balanced design presents an equal resistance on both input-output lines, but why is this desirable in, for example, an audio application, or indeed any other application?
    Thanks a lot.
  2. Prodigal
    Oct 12, 2006
    10
    Seems I was being silly. Is it that a balanced attenuator is for use with balanced signals? ie. 2 inputs 180 degrees apart?
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Having Balanced Audio is desirable, but an attenuator is an attenuator, you use the correct type for the transmission line in use.
