Balanced 3-phase circuit
Discussion in 'Homework Help' started by hitmen, Jan 8, 2010.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    Q1) The question is about a 440-V balanced 3-phase Y-connected circuit.
    May I ask is the 440V phase voltage or line-to-line voltage and why?
    Q2) I know the equation Iline = Vphase / (Zline + Zload)
    Why is the voltage in phase but the current is line to line?:confused:
  2. JDT
    Feb 12, 2009
    658
    85
    Q1 In a balanced 3-phase circuit the voltage is line to line. The centre of the Y (or star) is not connected. (sometimes it is connected to earth)
    Q2 Don't forget that the currents in each of the 3 loads are 120deg phase difference. The current in each line is the phasor resultant of the current in two loads.
    Hope this makes sense!
  3. hitmen
    Sep 21, 2008
    159
    Hi JDT thanks for the help
    Regarding A what happens if the structure is delta shape instead?
    I dont understand b. Dont 120+120 degrees = 240 degrees?
