Backwards dimensions in Eagle
Discussion in 'General Electronics Chat' started by GRNDPNDR, Apr 1, 2014.
  1. GRNDPNDR
    Mar 1, 2012
    449
    7
    My dimensions in eagle are all backwards when I place them. Does anyone know how to fix this?
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Any text/dims etc will appear reversed when they are on a bottom layer (solder side, bottom silkscreen etc). The board view is from the top looking through the many transparent layers. If you want, you can use info->properties on the strings and uncheck Mirror there.
    You can change they way they plot in the CAM job by unchecking Mirror on the various tabs corresponding to bottom layers. Keep in mind that in film processing, its done this way (bottom layers mirrored) so that the emulsion side of the film is next to the board for best resolution.
  3. sirch2
    Jan 21, 2013
    1,008
    351
    As JohnInTx says, you could also change the layer to the top layer before placing the dimension
