Not worried about destroying the battery as it is documented that the battery should be removed before using connecting external power.Yes, it's an issue. That will eventually overcharge a battery that isn't meant to be recharged. It may not be terribly unsafe, but it will destroy the battery. A blocking diode would solve the problem but you don't have much voltage to work with. A switch of some kind might be a better solution.
Thanks, did not know of that part.You could use an ideal diode such as this to prevent the battery from being charged
Thread starter | Similar threads | Forum | Replies | Date |
E | Diodes in AC circuit backfeed protection | General Electronics Chat | 1 | |
B | Question CR2032 battery | General Electronics Chat | 26 | |
I | LM7805 in reverse - will it backfeed? | Power Electronics | 11 | |
R | LED Sign Backfeed Problem | General Electronics Chat | 1 | |
Backfeed Issue - How to resolve? | Power Electronics | 3 |
by Jake Hertz
by Duane Benson
by Jake Hertz
by Aaron Carman
