Hi all,
I have designed a little circuit to turn on a 230V dosing pump through an SMS controller (part of bigger project)
I am worried about the relay's sticking as if this happens it will be a disaster..The end relays im using are here of which energise the 230V pump
http://www.maplin.co.uk/6-and-12v-6a-miniaturerelays-2525
The 12V side of the above relay is triggered by one of these
http://www.hunters-wholesalers.co.uk/12v24v-secsmins-timer-8amp-doublepole-relayis-p-2621.html
of which is initially triggered by a 1 second pulse from the sms controller this way I can set exactly how many seconds/minutes the pumps stay on for and as of my calculations the dosing pump delivers 33ml per minute
If the dosing pump some how decides to keep running due to the end relay sticking or whatever I will be screwed...I am wondering if theres a way of adding another relay that works with the end relay so that if one becomes faulty and stays on the circuit will be broken?
