I have been working my way through the basics for a few projects. I had some luck with the 555 and then moved on to a few other components that I was struggling with a bit.
I have attached a circuit that I made (free software, and my first time so please overlook the mistakes).
I think I included most of the relavant info. Please let me know if I missed something. It may be blind luck, but the circuits works like I wanted it to. I really tried to follow some circuits I found and tried to build/modify it with what I had. Laser hits the LDR and the green LED comes/stays on. No laser, buzzer starts buzzing.
I know the circuit shows 18V and the MAX for the 555 is 18V, but the measured Vcc was actually less (2 9V's, 1 used some). I wasn't sure what the correct method of labeling would be.
Unless you guys tell me I need to fix major items, my next steps and therefore questions to you guys are:
1. I have used batteries so far, but I would like to use a power supply for these circuits. I would like to use some large, push buttons I have found to "Start" the sensor circuits (plan on 3 separate ones). Desc: Momentary-action, S.P.D.T lighted pushbutton switch for displays and games. Rated 5 Amps @ 125/250 Vac. The assembly is lighted with a replaceable 12 Volt, 3 Watt, #161 wedge-base lamp. I have not even started looking into power supplies. Based on the level of difficulty, would it be better for a newbie to purchase something?
2. I plan to have Flashing lights start if/when the light is broken. I am looking at: Protected against polarity reversal. Fully Sealed and waterproof. Power output: 1W. Power supply: 12 Vdc I know the buzzer I have used for the proto is 12V, but I have also found some flashers with sirens. I was not sure about how/what my options were coming out of the circuit so I stayed in the smaller range. If I go with the flasher listed above, can I just use the current setup?
3. And finally, to hyjack my own thread. I have been looking into 2 other projects - Game Show Type Set-Up and Finding a Set-Up to Measure Speed of Some of my wrestlers doing certain moves. Can I use a similar circuit in these 2 projects? I know the light/dark would have to be tweeked because we do not do a lot of wrestler practices in the dark. Maybe some sort of motion indicator? Could I dial in the sensitivity with the pot. to still use the laser/LDR set-up? I was strugging with a circuit I found to trigger a stopwatch on and off, but I was thinking I could use this if the sensitivty was there.
Sorry about the novel. It is very late and I was rambling a bit there. I will say this site has been an incredible resource. Not only the forum, but the info listed as well.
THANK YOU!
Steve
THANK YOU!
Steve
