Back EMF protection
Discussion in 'General Electronics Chat' started by xxxyyyba, Jan 25, 2016.
  1. xxxyyyba
    Aug 7, 2012
    249
    Here is schematic that provides polarity inversion and switch off motor if it reaches one of its two end positions:
    SW1 is On-Off-On DPDT switch with the center position Off. SW 2 and SW 3 are limit switches. Motor voltage and amperage are 12V and 2A (max.).
    Should I add back EMF protection and, if yes, how can I implement it in my case?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Since you're using mechanical, you might be OK without back EMF protection. However, your switches might have degraded life-times, and it wouldn't hurt. You need two diodes across your DPDT switch on the motor end between "FWD" and the center contacts, and "REV" and center contacts, each reversed biased for normal current flow (ie, cathode on "FWD" anode to center contacts, anode to "REV" , etc.)
    However, you'll need to reverse the order of your FWD/REV switch and limit switches for this to work.
    xxxyyyba likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
  4. crutschow
    Mar 14, 2008
    13,475
    3,362
    You can also place the 4 diodes at the motor connection.
    Connect one at each motor connection to V+ (anode to motor) and one at each motor connection to V- (cathode to motor).
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    A motor that is revolving at turn off exhibits a BEMF in the same polarity as the supply, the level of which is dependent on rpm it is rarely needed in especially in a relay operated circuit.
    Max.
  6. xxxyyyba
    Aug 7, 2012
    249
    Like this?
    I thought it's better to open new thread, than to write in old one :)
    Do you have schematic because I'm not sure I understood? :)
  7. Brownout
    Jan 10, 2012
    2,375
    998
    That'll work.
  8. Dodgydave
    Jun 22, 2012
    5,141
    767
  9. xxxyyyba
    Aug 7, 2012
    249
    There will be problem, when DPDT is in this configuration:
  10. xxxyyyba
    Aug 7, 2012
    249
    Thanks for reply.
    On that way, there is no need for three wires, right?
    Similar to this schematic (thanks MaxHeadRoom):
  11. Dodgydave
    Jun 22, 2012
    5,141
    767
    Correct.
  12. crutschow
    Mar 14, 2008
    13,475
    3,362
    Those diodes won't protect the limit-switch contacts when they open.
    For that you need an added diode at D1's anode (anode of new diode to B ground), and one at D2's cathode (cathode of new diode to V+).
    If you follow the direction of the inductive motor current when a contact opens, you will see why you need the added diodes.
  13. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    What about the generated voltage in the same polarity as the supply?
    You only have to back feed a PM motor to see this.
    Max.
  14. Brownout
    Jan 10, 2012
    2,375
    998
    Just add a pair of 15v zeners across the motor. Anodes connected to motor wires, cathodes connected together.
  15. crutschow
    Mar 14, 2008
    13,475
    3,362
    Don't understand your question. :confused:
    The added diodes I suggested will protect the limit switches from inductive spikes for both motor directions.
  16. xxxyyyba
    Aug 7, 2012
    249
  17. crutschow
    Mar 14, 2008
    13,475
    3,362
