back ache
Discussion in 'General Electronics Chat' started by mxabeles, Jul 15, 2010.
  1. mxabeles
    Thread Starter Active Member
    Apr 25, 2009
    182
    hey there forum,
    i've been busy with clients and have had little time for my own work recently.
    This means i'm still bent over the soldering table and i'm feeling the burn.
    Anyone have good solution to prevent back injury from being keeled over the soldering iron 8 hours a day?
    Thanks,
    -M
  2. davebee
    Oct 22, 2008
    539
    46
    I had this problem until I raised the height of my worktable so I could work at it standing up.
    For most assembly work, the standing position has been great for my back.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    yeah raise your worktable some, and if sitting when doing it have the workpiece up high enough to where you do not have to "bend" down to look at it.... I, as Davebee has, have my workbench up higher to where I stand when doing PCB assembly work, much more comfortable to work and can get at anything when needed, which I find my movements a little more restricted when sitting....
    B. Morse
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Raise your work table, or lower your chair. ;)
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You are experiencing problems with the ergonomics:
    http://en.wikipedia.org/wiki/Ergonomics
    It all has to do with how you are sitting on your desk,
    what movements you have to make, (stretching, lifting)
    and also the enviromental conditions.(light, dust)
    Bertus
  6. KL7AJ
    Nov 4, 2008
    2,043
    292
    You can solder while lying on your back. :) (Wear goggles!)
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One tradition is to make lots of money so you can hire someone to do the hard stuff.
  8. retched
    Dec 5, 2009
    5,201
    313
    hear-hear!
  9. mxabeles
    Apr 25, 2009
    182
    thanks for the feedback, everyone. I must say I'm going with KL7AJ on this one tho, its just such an elegant solution. :)
  10. someonesdad
    Jul 7, 2009
    1,585
    141
    Actually, the most convenient method of soldering is in zero-g, so either hire the Vomit Comet or get on the next trip to the ISS.
    Seriously, another contributor to the problem is not enough movement. My sister is a PT and has given me lots of comments about this. Get up and move about the room, the more frequent your breaks the better. Stretch. Do isometrics. Every half hour isn't too frequent, although many folks do it every hour or so. Your posture is very important, so you might even want to consult with an expert. PTs are good at this stuff, so don't hesitate to consult with them.
    But the real answer was already given. Have you heard Bill Gates complain about back pain from soldering? :p
