Hi All,
The LED in the datasheet attached is a Ba9S type (130V) which has internally an array of 7 LEDS.
I am trying to add a resistor to reduce the current into the LEDs.
These are the things that I can not figure out:
Ros
- the array of 7 LEDs in asingle bulb is connected in series or parallel?
- The 5.9mA refers to the current of the single LED of the whole array (if in parallel)?
- Can I assume the internal resistor is 22kOhm (130/5.9)?
Ros
