B1M potentiometer
Discussion in 'General Electronics Chat' started by atlantis43, May 7, 2014.
  1. atlantis43
    Apr 30, 2014
    15
    wondering if anyone can tell me if the leads on all B1M pots should correspond to one another, no matter the manufacturer?
  2. atferrari
    Jan 6, 2004
    2,669
    784
    As far as I know the middle one, in common pots is always the slider.
    Show a picture of the one you are thinking of.
    Still struggling with that pot?
  3. atlantis43
    Apr 30, 2014
    15
    Yes: finally found the markings on the pot switch! There was a microscopic B1M on it, for which I needed a jewelers loop.
    Can't send a pic, as I dismantled the original, but wires were connected to lugs 2 & 3.
    I got a new B1M pot-switch, and on the original the wires were connected across lugs 2 & 3.
    My question regards whether my new unit will perform like the old one if I make the same connections------or do any pots function in reverse?
    Hope that my question is understandable.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Some pots work, "backwards" but a linear, 1 meg pot is just so simple that i think I must have missed some other thread to understand why you have doubts.
  5. atlantis43
    Apr 30, 2014
    15
    Glad to know that. I just wasn't sure if any were constructed in reverse.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    The key word here is, "linear". The resistance changes in an even rate from one end to the other. In other words, a linear pot can't be backwards, only pots with a different rate of change can be backwards.
    There is a particularly famous, backwards, 3 meg pot used in Fender guitar amplifiers but you must be able by now to recognize that it must be an audio taper or it couldn't accomplish working backwards.
  7. atlantis43
    Apr 30, 2014
    15
    having replaced the B1M pot switch, I find that the dimmer switch now works, but it appears that the bulb never seems to dim to as low a level as previously (with the original switch).
    I assume that the maximum resistance of both pots is 1MΩ, is it possible that the minimum Ω of this new pot switch is different than the original?
  8. inwo
    Nov 7, 2013
    2,435
    315
    Maximum resistance = lowest light level.
    Compare maximum resistance.
    All pots I've seen go to 0 ohms.
  9. atlantis43
    Apr 30, 2014
    15
    Shouldn't all B1M pots have same maximum resistance = 1M, or is there something I don't understand about the designation B1M ?
  10. #12
    Nov 30, 2010
    16,704
    7,354
    There is tolerance error. Most pots are guaranteed to +/- 10% of the rated value, and, unlike inwo, I have rarely found one that goes all the way to zero ohms. Still, it usually doesn't matter, especially in a dimmer. They are fairly crude devices that don't get very far off the target, even with a 10% error (compared to the math).
    Don't get microscopic with this. You'll run yourself crazy.
    If you want 0.0 ohms to 1.00 million, you have to buy a, "precision" potentiometer.
    atlantis43 likes this.
  11. inwo
    Nov 7, 2013
    2,435
    315
    Try with pot disconnected. Maybe something else is afoot.
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
