AZ1117D become hot
Discussion in 'General Electronics Chat' started by tsamotawer, Aug 7, 2015.
  1. tsamotawer
    Aug 7, 2015
    Hi ,
    I am new here so please let me know if I am not in the right forum , thanks
    I have a surveillance movable camera (it has two motors) and it stop working and I have opened and checked its circuit board for repair I have noticed that the AZ1117D 3.3v become very hot???? . thanks
  2. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Overheating of linear VRs is most generally upshot of overload (excessive current drain) you are advised to check any electrolytics and go from there... Please keep us posted :)
    Best regards
    HP
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    AS HP mentioned over current will heat-up the regulator.
    Are the motors also powered from the 3.3 Volts?
    If so, check if they are not stalled.
    Bertus
  4. tsamotawer
    Aug 7, 2015
    Thanks.
  5. tsamotawer
    Aug 7, 2015
    YES the motors also powered from the 3.3 Volts I have disconnected the motors cable and WIFI module the IR diodes the regulator still overheated.. the power supply supposed to give 5v output (as stated in the manual) but it give about 8v output instead??
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    When the powersupply is giving 8 Volts in stead of the mentioned 5 Volts, the regulator will have to drop 4.7 Volts in stead of 1.7 Volts.
    This voltage drop is multiplied by the drawn current.
    This power must be dissipated by the voltage regulator.
    The regulator will have to dissipate 2.76 times more as when the powersupply was 5 Volts.
    Bertus
  7. tsamotawer
    Aug 7, 2015
    Hello Bertus,
    I will try another 5v powersupply and see , thanks
