AWG gauge choice and assistance!!
Discussion in 'General Electronics Chat' started by gusmas, Jul 22, 2013.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Hi
    I need to wind a inductor which will experience the following:
    It will be used in a buck-boost converter.
    PWM Freq: 20kHz
    Max Load Current: 20A
    Now using the following link: http://www.powerstream.com/Wire_Size.ht,to get the wire thickness. However the wire that can handle 20kHz (AWG 19) is only able to handle 1.8A?
    Am I missing something here? I hope I am.....
  2. PackratKing
    Jul 13, 2008
    850
    216
    The link provided, indicated a URL fault, but gave a route to the "ampacity" table.
    You need something to handle 20 amps, this will be at least # 12 awg.
    Re; A standard household AC Outlet, provides 15 amps, and is wired with a minimum 14 awg. Please refer to National Electrical Codes...
    Frequency will speak for itself, as a function of the core material you wind your project on... and the number of turns to do the deed. Those are your major considerations, and more math than is called for here...:D
  3. gusmas
    Sep 27, 2008
    239
    whoops:
    http://www.powerstream.com/Wire_Size.htm
    if I may ask how did you get I must use at least a #12 awg? Was that a estimation from the "Re; A standard household AC Outlet, provides 15 amps, and is wired with a minimum 14 awg." statement?
  4. Evil Lurker
    Member
    Aug 25, 2011
    117
    24
    The inductor would have to be huge to support that frequency (along with the wire gauge) and so would the caps to handle the ripple current. You need to increase your frequency to 100khz+ IMO.
  5. gusmas
    Sep 27, 2008
    239
    Cap is sorted. Just need my inductors :)
  6. Evil Lurker
    Member
    Aug 25, 2011
    117
    24
    How much inductance do you need?
  7. gusmas
    Sep 27, 2008
    239
    any value between 20uH and 500uH
  8. BobTPH
    Jun 5, 2013
    807
    121
    Haven't designed many switching power supplies, have you?
    Bob
  9. gusmas
    Sep 27, 2008
    239
    no, designed from what info i could find on internet.
  10. PackratKing
    Jul 13, 2008
    850
    216
    I am a 40+ year household DIY, and have done beau-coup wiring, and even though not "licensed" I work under the purview of a licenced electrician, and subject to the same NEC and local codes, just as he is...
    regarding electricity - amps are amps, whatever house they live in... whatever any given component tells it what to perform... it takes #12 awg or [sch]metric equivalent , to handle 20 amps current. Some will tell you that #14 is ok, here's the difference... I tend to lean toward overkill with things Electric / electronic.
  11. BobTPH
    Jun 5, 2013
    807
    121
    I suggest you do some simulation then, or analysis to determine a little more carefully what inductor you need. A 20uH and 500uH will perform very differently.
    What are the input and output voltage and current requirements?
    Bob
  12. wayneh
    Sep 9, 2010
    12,394
    3,246
    Not if that "house" is a coil that cannot dissipate much heat. Linear insulated wire ratings would be different than coiled magnet wire inside a shielded enclosure.
    PackratKing likes this.
  13. gusmas
    Sep 27, 2008
    239
    I have simulated my design for both inductor values and it worked as intended (i think its luck :p). Maybe my mistake was saying between 20u and 500u (inexperience). Lets say either of those values, i need a inductor for.
  14. BobTPH
    Jun 5, 2013
    807
    121
    With a load of 20A and you got the same results?
    Bob
  15. gusmas
    Sep 27, 2008
    239
    yes. See attached documents. first one is at 20uH, second one is 500uH
      File size:
      89.8 KB
      15
      File size:
      91.3 KB
      17
  16. tindel
    Sep 16, 2012
    576
    196
    Can you really take ~25V of overshoot on your 50V rail? That's 50% overshoot, and I see it on both simulations.
  17. gusmas
    Sep 27, 2008
    239
    That is without soft startup. I am going to use a micro to control the pwm duty cycle, so will start at close as possible to 0% and slowly ramp it up.
