AVR Zero Cross Detection and AC Light dimmer
Discussion in 'Embedded Systems and Microcontrollers' started by taher, Jul 8, 2014.
  1. taher
    Jul 8, 2014
    Hi all,
    I am working on AC dimmer circuit , for that i have have interfaced the Zero Cross Detection circuit with ATmega16 INT0 pin. INT0 is configured as a rising edge. here i am attaching image which shows the working of Zero cross detection is good. but when i interface its output with ATmega INT0 pin, the Zero Cross Pulsed gets down and nothing happen on INT0 pin. i have tested INT0 code separately which also working as expected. I am not getting where i am doing anything wrong? please somebody help me who has worked with such project ever before
    Here is a code snip which gives INT0 routine and Int0 Configuration as rising edge.
    Code ( (Unknown Language)):
    1.
    2. /*  *  Written in AVR Studio 5 / AVR Studio 6  *  Compiler: AVR GNU C Compiler (GCC)  *  *  Author: AVR Tutorials  *  Website: www.AVR-Tutorials.com */   #include <avr/io.h> #include <avr/interrupt.h>   #define F_CPU 16000000UL #include <util/delay.h>   #define DataPort  PORTC   // Using PortC as our Dataport #define DataDDR      DDRC  //Interrupt Service Routine for INT0 ISR(INT0_vect) {     unsigned char i, temp;  cli();  //_delay_ms(500); // Software debouncing control    //temp = DataPort;  // Save current value on DataPort       /* This for loop blink LEDs on Dataport 5 times*/   DataPort = 0x00;    for(i = 0; i<100; i++)  {               _delay_us(200); // Wait 5 seconds           //_delay_us(200);   // Wait 5 seconds   }   DataPort = 0xFF;    //DataPort = temp;  //Restore old value to DataPort     sei(); }       int main(void) {     DDRD = 1<<PD2;      // Set PD2 as input (Using for interupt INT0)   PORTD = 1<<PD2;     // Enable PD2 pull-up resistor      DataDDR = 0xFF;     // Configure Dataport as output     DataPort = 0xFF;    // Initialise Dataport to 1         GICR = 1<<INT0;                 // Enable INT0  MCUCR = 1<<ISC01 | 1<<ISC00;    // Trigger INT0 on rising edge      sei();              //Enable Global Interrupt      while(1)     {   /*  if(DataPort >= 0x80)            DataPort = 1;       else            DataPort = DataPort << 1;   // Shift to the left        _delay_ms(500); // Wait 5 seconds */        if(!(PIN_1 & (1<<SW_1))) //If switch is pressed         {           toggle(LED_PORT,LED_1);             _delay_ms(1000);        }       else if(!(PIN_1 & (1<<SW_2))) //If switch is pressed        {       toggle(LED_PORT,LED_2);         _delay_ms(1000);        }     } }
    3.
    When i use this Zero Cross Detection pulses as a normal switch its working good, but when i use it with INT0 pin the pulse get destroyed and nothing happens as attached images
