AVR to printer interfacing
Discussion in 'Embedded Systems and Microcontrollers' started by ne89, Jan 4, 2007.
  1. ne89
    Sep 25, 2006
    9
    hello,
    Does anybody knows how to interface ATmega16 to serial or parallel printer directly?
    Because my printer has 2 ports, which one is easier to make the code ?
    How can printer know the command from AVR that it's for font setting, margin setting, start/stop printing and etc ?
    Any information from you is helpfull to me.
    Thanks,
    ne89
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The manufacturer of the printer will have the information necessary to send data to it. There should be a complete description of the interface, including all control signals.
    I don't know how easy it will be to get this information. Printers get shipped with elaborate driver packages to let them function under Windows. You used to get all this information in the manual, but now all you get is instructions on how to unpack it. You will need specific information for any printer you are planning to use.
    I suspect you need to do some more work with your microprocessor in order to understand the concept of interfacing better. AVR has many guides and how-to's on line, which is a good source of information.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Be aware the that some ATMEGA16 devices are shipped with the JTAG port (PORTC bit3, bit4, bit5, bit6) enabled. If you plan to use these bits from PORTC you may need to reset the internal fuse to disable JTAG feature.
    hgmjr
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    What brand and model printer? What sort of connection did you want to make?
  5. ne89
    Sep 25, 2006
    9
    hi,
    I want to use epson TM220D with serial communication.
    Which one is easier to interface serial or parallel?
    Thanks.
    ne89
  6. n9352527
    Oct 14, 2005
    1,198
    This is a commercial impact printer, and usually have their own codes and interfaces. You need to get hold of the printer manual. Go to Epson-pos website and you need to register to download the manual. TMU220 is the newer equivalent model.
    Then, it is just a matter of sending the appropriate codes to control the printer.
    I would go for serial, simply because it needs less pins to work.
