avr studio programmer attiny26
Discussion in 'Programmer's Corner' started by LaurenceR, May 12, 2014.
  1. LaurenceR
    Feb 7, 2013
    97
    I up loaded a hex file to the MCU and it doesn't seem to run. Have not done a lot of programming. what I have done is mainly in assembly, the program was written by someone else in C. Usint Mark II and studio 4. Any help would be appreciated.
    Thanks.
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    We can't help you much without the source code listing.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    ...and a schematic showing your connections...
  4. LaurenceR
    Feb 7, 2013
    97
    I'll get them.
  5. LaurenceR
    Feb 7, 2013
    97
    Attached is the schematic of the circuit. The main circuit I am testing is in the top half of the view. the bottom is for a 4 - 20 ma vcontrol signal that can also go back to the MCU. I had these developed for me some time ago but attempting to do my own programing and uploading. One comment I have is that avr studio 4 doesn't bring up ATtiny26 or the mkII ISP. tried to use something close. Not good.
    Looking for the C file have only found the hex and test files. I actually tried uploading the hex file. Not successfully.
    thanks.
  6. LaurenceR
    Feb 7, 2013
    97
    I am finding that the attiny 26L is not listed in any of the programming and debugging devices. the last time I programmed them I used the stk500 board which is now obsolete. Does anyone know if the attiny 26L is no longer supported?
    Thanks,
  7. MrChips
    Oct 2, 2009
    12,636
    3,454
    The ATtiny26 is still in production and fully supported.
    The STK500 will program the ATtiny26.
  8. LaurenceR
    Feb 7, 2013
    97
    OK, let me start here.No longer have the STK500 board. I purchased a MK II ISP. Should this work with either studio 4 or 6? Do I need some other isp programmer?
    Thank you.
  9. MrChips
    Oct 2, 2009
    12,636
    3,454
    MK II will work with Studio 6 as well as Studio 4. Download the latest Studio 6.2
    You would get better answers if you post your questions on Atmel AVR forum.
  10. tshuck
    Oct 18, 2012
    3,531
    675
    You can't just use another programming method/device. You will probably have to add definitions of the tools/devices with which you are working.
  11. LaurenceR
    Feb 7, 2013
    97
    I thought I installed all the drivers for the MK II however only jtag ice shows up and not MK II isp. Not sure what is going on or what to do.
    thanks.
