AVR ISP programmer
Discussion in 'General Electronics Chat' started by stylediva, Aug 14, 2012.
  1. stylediva
    Dec 6, 2011
    72
    i need to make avr isp usb programmer which is available here:
    http://www.fischl.de/usbasp/
    if i use normal diodes instead of zeners, will it work??..guide me plz..
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    No, diodes will not work.
    You don't need zeners anyway. You can omit D1 and D2.
  3. stylediva
    Dec 6, 2011
    72
    will it work without diodes??
    can i use crimp shell instead of ISP connector??
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    Yes and yes.
  5. stylediva
    Dec 6, 2011
    72
    please tell me the connection of ISP conneector with avr atmega16..which pins of ISP connector shoul b used with it??
  6. stylediva
    Dec 6, 2011
    72
    if i use crimp shell ,the connections will b like this??
    PB3(MOSI/OC2) of atmega8 with MOSI OF ATMEGA16
    PB4(MISO) of atmega8 with MISO OF ATMEGA16
    PB2(SS/OC1B) of atmega8 with RESET of atmega16
    PC6(/RESET) of atmega8 with RESET of atmega16
    PB5(SCK) of atmega8 with SCK of atmega16
  7. stylediva
    Dec 6, 2011
    72
    WILL IT BE LIKE THIS??? 5 PINS OF CRIMP SHELL WILL BE USED LIKE THIS??
    PB2(SS/OC1B) of atmega8 with SS PB4 of atmega16
    PB3(MOSI/OC2) of atmega8 with MOSI PB5 OF ATMEGA16
    PB4(MISO) of atmega8 with MISO PB6 OF ATMEGA16
    PB5(SCK) of atmega8 with SCK PB7 of atmega16
  8. n1ist
    Mar 8, 2009
    171
    16
    Don't forget a common ground between the programmer and the device being programmed.
    /mike
  9. bretm
    Member
    Feb 6, 2012
    152
    24
    You shouldn't need SS pin hooked up on the target. It may be using SS on the host to drive RESET on the target. The programmer I use just has MISO, MOSI, SCK, RESET, VCC, GND. SS is needed for SPI in slave mode but programming is a special mode.
  10. stylediva
    Dec 6, 2011
    72
    where should the diodes be connected??..before or after the 68 ohm resistor??should they be connected with D- and D+ Pins of usb connector??
  11. MrChips
    Oct 2, 2009
    12,652
    3,461
    Leave out the diodes.
  12. stylediva
    Dec 6, 2011
    72
    please check and verify this circuit..will it work??
  13. MrChips
    Oct 2, 2009
    12,652
    3,461
    MOSI and MISO must be crossed.
  14. stylediva
    Dec 6, 2011
    72
    MOSI of atmega16 is pin no 6 which is connected with MOSI of atmega8 which is pin no 17..what is the mistake??..
  15. MrChips
    Oct 2, 2009
    12,652
    3,461
    Connect MOSI of ATmega16 to MISO of Atmega8
    and MISO of ATmega16 to MOSI of Atmega8
    (I think).
  16. stylediva
    Dec 6, 2011
    72
    i heve seen this schematic..will it work???
