AVR ISP Programmer
Discussion in 'General Electronics Chat' started by lubnaan90, Mar 9, 2010.
  1. lubnaan90
    Thread Starter Active Member
    Jan 13, 2010
    196
    Hi to all ,
    Need help with AVR ISP systems.
    Plz allow me to inform that Its my first time using AVR ISP's (newbee) .
    As i am using a Laptop , its lacks an LPT port or a Com port , which is very much required to program Atmel chips i suppose.
    I am planing to use either one of the following ,
    1) USB to DB9/DB25 Adapter
    2) USB AVR ISP.
    Any kind of help/advise/recommendations will be deeply appreciated.
  2. Razor Concepts
    Oct 7, 2008
    212
    If you plan on getting into AVRs seriously, get a USB ISP programmer. If you can spend the money buy the official programmer, the AVR ISP MKII. If you want to go cheap, Sparkfun, Pololu and Adafruit sell budget USB programmers.
  3. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    What are the benefits of the AVR ISP MKII over the budget USB programmers?
  4. lubnaan90
    Jan 13, 2010
    196
    Thank you for your Reply ,
    Noted your points.
    Can i get Detailed instructions on how to use an USB ISP programmer, I mean what is to be done with the ISP header cable?
  5. Razor Concepts
    Oct 7, 2008
    212
    One main reason is that the MKII is constantly updated to handle the latest AVR devices. Any budget programmers can handle the standard 8-bit megaAVR/tinyAVR line, however the MKII can handle a lot more. For example, when the XMEGAs were released the firmware of the MKII was updated for PDA programming of the XMEGA.
  6. lubnaan90
    Jan 13, 2010
    196
    Is it ok to use AVR 910 USB.
  7. Razor Concepts
    Oct 7, 2008
    212
    If you are only programming the devices specified in the datasheet, then yes it should be fine.
  8. lubnaan90
    Jan 13, 2010
    196
    I just want to start with programming Atiny-2313 chip , for my led scrolling display project.
  9. Rush
    Oct 12, 2009
  10. t06afre
    May 11, 2009
    5,939
    1,222
    If you have the money I would go for a USB programmer. The best thing is to get a programmer that is supported by the chip manufacturer. So you can receive firmware updates and support for new MCUs
  11. Bosparra
    Member
    Feb 17, 2010
    79
    Why not build a usb programmer? I am using this one http://www.fischl.de/usbasp/
    You do however sit with the chicken and egg situation, you need a programmer to build this. But, it's a simple circuit to build, provide you use the right zeners.
