Is the manual to which you are referring the file avr-libc-user-manual.pdf ?I downloaded WinAVR and found the user manual but it is not very good like the CCS manual.
What is your suggestion about programming AVRs in C?
Yes it is.Is the manual to which you are referring the file avr-libc-user-manual.pdf ?
hgmjr
That's a good way to get started. Have you sketched up a rough schematic of your design? Once you do I will be glad to provide you with any assistance you need in getting your first program up and running.No, I don't have a development board. I am planning to make one with a ZIF socket and terminal blocks as to be able to connect anything on it.
I have bought some ATMEGA8-16PU uCs.
ATMEGA48/88/168 would be a much better choice.I have bought some ATMEGA8-16PU uCs.
