AVR (atmega16) LCD interfacing problem
Discussion in 'Programmer's Corner' started by electron_prince, Nov 28, 2013.
  1. electron_prince
    Sep 19, 2012
    93
    Hello guys,
    I've a program which contains this code
    Code ( (Unknown Language)):
    1. #define rs PB0
    2. #define rw PB1
    3. #define en PB2
    and later it is used as
    1.
    2. void lcd_cmd(int x)
    3. {
    4. PORTB=x;
    5. PORTB &= ~(1<<rs);
    6. PORTB &= ~(1<<rw);
    7. PORTB |= (1<<en);
    8. _delay_ms(2);
    9. PORTB &= ~(1<<en);
    10. }
    11.
    My question is why we used PB0, PB1 and PB2 instead of 0, 1 and 2 ??
    doesn't the below code make more sense?
    1. void lcd_cmd(int x)
    2. {
    3. PORTB=x;
    4. PORTB &= ~(1<<0);
    5. PORTB &= ~(1<<1);
    6. PORTB |= (1<<2);
    7. _delay_ms(2);
    8. PORTB &= ~(1<<2);
    9. }
    Please help, it's very urgent.
    Thanks.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Why would someone write
    1.
    2. PORTB |= (1<<2);
    when it is easier to write
    1.
    2. PORTB |= 0x04;
    The reason one would choose to write PB0, PB1, and PB2 is that one could easily change the port assignments to different pins, for example PB5, PB6, PB7.
  3. electron_prince
    Sep 19, 2012
    93
    sorry I didn't mean that. What I wanted to say is why not use this code
    1.
    2. #define rs 0
    3. #define rw 1
    4.  #define en 2
    5.
    which will produce
    1.
    3. {
    4. PORTB=x;
    5. PORTB &= ~(1<<0);
    6. PORTB &= ~(1<<1);
    7. PORTB |= (1<<2);
    8. _delay_ms(2);
    9. PORTB &= ~(1<<2);
    10. }
    11.
    why we are writing PB0 instead of 0 in #define
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Statements such as
    1.
    2. #define rs PB0
    belong in a .h header file, not in the main code or module.
    This allows one to reuse the same code even though the hardware assignment has changed.
    This is simply sound systems design practice.
    Better still, one could use
    1.
    2. #define LCD_PORT PORTB
    3. #define rs 0
    4. #define rw 1
    5. #define en 2
    6.
    This would allow you to choose any port and pin.
    electron_prince likes this.
  5. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Because people are not computers.
    People will at least have a feeling as to what PB0 means, as opposed to "0".
    What does "0" mean? That is extremely dependent on the contest.
    PB0, given the general context of doing a program, has but one meaning: the lowest pin of a port.
    A very wise man once said "Never put a magic number into your code."
    "0" is a magic number. "PB0" is well on it's way to being a self-documenting symbol.
  6. ErnieM
    Apr 24, 2011
    7,435
    1,625
    That is NOT better. You are using magic numbers.
    While you state WHERE they are used you do not state WHY they are used.
    1.
    2. #define rs PB0
    3. #define rw PB1
    4. #define en PB2
    5.
    Shows everyone the port pin rs uses, while the former is quite obscure.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    This will work because PB0, PB1 and PB2 are defined as 0, 1, 2.
    Ernie is correct because if you wanted to change to PORTE, for example:
    1.
    2. #define LCD_PORT PORTE
    3. #define rs PE5
    4. #define rw PE7
    5. #define en PE2
    6.
    would also work.
    Edit: Of course you do have a problem if rs is PB0 and rw is PE7, for example.
