Average Power Consumption of an AC Solenoid
Discussion in 'General Electronics Chat' started by AndersonA, Aug 5, 2016.
  1. AndersonA
    Dec 28, 2015
    10
    Hello all,
    I need to find the power consumption of an AC Solenoid, but can't seem to locate the correct way to do this. (I need to do it on paper, so no tools)
    The solenoid is 240VAC @ 60Hz with a coil resistance of 26 Ohms.
    When "seated," it draws 0.33A of current.
    Can I use this information to solve for the power?
    If so, how?
    Thanks!
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The power is a product of the current and voltage, you can also roughly find out the inductive reactance the 26ohms coil resistance will be in series with this.
    Max.
  3. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Is this a Homework/Exam question?
  4. AndersonA
    Dec 28, 2015
    10
    No. I am trying to understand a datasheet for a Laminate solenoid.
  5. AndersonA
    Dec 28, 2015
    10
    This is in regards to a Dormeyer 3001-M-1 solenoid.
    At "seated," the datasheet says it consumes 23.5 Watts. That number isn't the product of 240 and 0.33.
    Although I do have the answer, I need to understand the process behind the answer.
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  7. AndersonA
    Dec 28, 2015
    10
    I've actually already read that page while trying to come up with the answer myself. My problem is that I don't know the inductance and cannot therefore determine the phase angle. Correct?
    I'm trying to treat it as a resistor and an inductor, but am not having any luck trying to match the datasheet's power.
  8. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Can you post the datasheet?
    Bertus
  9. AndersonA
    Dec 28, 2015
    10
    Again, for reference, I'm looking at the 3001-M-1
  10. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  11. crutschow
    Mar 14, 2008
    13,502
    3,376
    You don't need to know or calculate the inductance, you just need the current through the solenoid resistance.
    Just multiply the square of the current times the solenoid resistance.
    This gives a solenoid power of 0.33A^2 * 26Ω = 2.83W.
    Since it states a power 23.5W there would seem to be a very high amount of eddy current loss in the core..
  12. AndersonA
    Dec 28, 2015
    10
    With regards to an AC solenoid, you're telling me that I can ignore the reactance?
  13. MrAl
    Distinguished Member
    Jun 17, 2014
    2,562
    517
    Hello there,
    One question: Does it get hot when it is 'seated' ??
    The power is calculated from the inductance, the DC resistance, and an equivalent resistance in parallel with the coil. We dont know what the equivalent resistance is without another measurement. For example, if you could measure the phase angle between the current and voltage, we could calculate the equivalent resistance and then the inductance also. That is to determine if they are right or not.
    But if we assume they are right, then we might be able to calculate the missing items knowing the power is 23.5 watts like the data sheet says, but a phase angle measurement would provide more information we could use to verify or disprove this.
  14. AndersonA
    Dec 28, 2015
    10
    As the solenoid would be dissipating some amount of heat, I'd imagine it gets "hot" over time.
    These solenoid datasheets are based on an 80 C rise in coil temp. from ambient.
  15. MrAl
    Jun 17, 2014
    2,562
    517
    Yes i could imagine too, but i was asking if you could feel it or better yet measure the temperature. That might help figure out if it was really dissipating 25 watts.
    A single measurement is worth 1000 data sheets :)
  16. crutschow
    Mar 14, 2008
    13,502
    3,376
    The reactance is only needed to determine the AC current.
    Since that is given in the data sheet, than all you need is the coil resistance (also in the data sheet) to determine the power dissipated in the resistance.
    But the power seems to be much higher than that calculation gives, which I don't understand. :confused:
  17. MrAl
    Jun 17, 2014
    2,562
    517
    Yes you do...core loss :)
    They are probably banging the core with high flux.
    That's unless they misquoted the spec of course :)
  18. crutschow
    Mar 14, 2008
    13,502
    3,376
    Well certainly there is some core loss, but from the spec values it would appear that all but a couple watts are due to that, which seems rather excessive.
  19. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Could the high value relate to the peak initial power when the solenoid is fully extended and has minimal inductance? Current is then 6.5A, rather than the 0.33A when seated, so the figures still don't seem consistent.
  20. The Electrician
    Oct 9, 2007
    2,301
    338
    No, you can't use this information to solve for the power. There is substantial core loss and the given information doesn't allow you to calculate what the core loss would be. To do so, you would need to know what grade of iron is used and what the maximum flux density is.
    Why do you need to be able to calculate the power consumption rather than just accepting the specification?
