Average Output Voltage
Discussion in 'Homework Help' started by AD633, Jul 9, 2013.
  1. AD633
    Jun 22, 2013
    96
    Calculate the average value of the output voltage (VODC) for the case that the voltage Vi equals to waveform on the figure.
    The circuit is a uppper limiter circuit,imposing  Vo=Vi or Vo=5V depending on the value of Vi,right?
    How can i calculate the average output voltagem?Do i have to do the integrals or can i compute the areas of the trapezoids?
  2. WBahn
    Mar 31, 2012
    18,093
    4,920
    How can we tell you if your transfer characteristic is right if you don't tell us which values of Vi correspond to which of the three output equations? For the record, the first is correct only at one point, the second is never correct, and the third is correct for a certain range.
