Average Forward Current
Discussion in 'Homework Help' started by wtfman, Oct 11, 2011.
  1. wtfman
    Oct 7, 2011
    12
    My try for this solution:
    Since its asking for the current through the diode only and it is silicon:
    Id1 = .7v/200 ohms
    = .0035 A
    i was thinking of the Idi as 50-.7/ 200 ohms = .2465. but that would be for the resistor right?
    Just trying to confirm
    Thx
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The second answer of 0.2465A is OK. Not sure where you were going with the first idea - definitely not correct.
  3. wtfman
    Oct 7, 2011
    12
    then what would the current be across the resistor
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    It's a simple series circuit - What do you know about the current in each component of a series circuit?
  5. wtfman
    Oct 7, 2011
    12
    its the same
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    So how would you answer your own question in post #3?
  7. wtfman
    Oct 7, 2011
    12
    just trying to make sure.
  8. Adjuster
    Dec 26, 2010
    2,147
    300
    It is much better to say the current through the resistor. What appears across a resistor is a potential difference, or more loosely a volt-drop or a voltage.
    If you remember "Voltage across, current through." you will be less likely to get confused by this sort of problem. You may also avoid the possibly expensive and hazardous mistake of connecting an ammeter across a supply.
