Im trying to build a Marx generator using Avalanche Transistors as switches. I Need to get pulses of 1kV or More. I have HAve done the schematic on LtSpice as seen on the attached Schematic. However, i need to characterize one of the Avalanche transistors to be the triggering switch rather than the Power MOSFET used.
I dont know how to do this and i would appreciate it if you could help as this is my last glitch before i can build it on a pcb.
Thank you in advance
Regards
Regards
