I am designing a relay which is based on MOSFET, this relay has 14 output.
The relay is being operated on 5V dc supply.The supply is being provided to the board by using a MOSFET, the attachment shows the power supply section and one of the output ciruity from the available 14 output.
TPC8124, Now I want to calculate the total available power that can be obtained through this relay board:
As I am given the input 5v supply to this transistor (TPC8124) which is further supplying this 5v to the rest of the board, the datasheet of this transistor says that Drain Current (DC) is -12 A, as my input supply voltage is 5v so I calculate that total output power that be get through this board is 60W.
is this a right estimation or I am missing something ??
The datasheet is available on the following link
http://www.toshiba.com/taec/components2/Datasheet_Sync/200912/DST_TPC8124-TDE_EN_11751.pdf
with regards,
Muhammad Faisal.
with regards,
Muhammad Faisal.
