auxiliary cargo lights with 2 switches?
Discussion in 'The Projects Forum' started by work.truck, Dec 13, 2014.
Thread Status:
Not open for further replies.
  1. work.truck
    Dec 7, 2014
    8
    I am hooking axillary cargo lights up to the back rack of my truck. I'm going to hook them to a switch on my dash simple enough. but I would also like to install a switch in the box of my truck. I would like to be able to turn the lights on from inside the truck or outside the truck. I know how to use relays I know how basic wiring works just looking for maybe some diagrams. I just want to make sure I do it properly I'm using led toggle switches and I don't want any back feed. I'm wondering if I can run the wire from each switch into one relay but just want to be sure. Any thoughts or ideas would be greatly appreciated thank you
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
  3. work.truck
    Dec 7, 2014
    8
    Ya im trying to do it with, spst self illuminating toggle switches. so it matches my custom switch panel. I want it just on/off from the box of the truck. And an extra on/off from the cab of truck. Both able to switch the same light. So its not really a "3 way switch" . Cuz if one switch was on the other switch would not do anything
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    The owners of All About Circuits has elected not to host discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
    This thread is against the AAC forum rules, Chapter 6, as seen here:
    This can be found in our Terms of Service (ToS)
    Automotive modifications of any kind are strictly forbidden. Therefore, this thread will be closed.
    Please try to understand the reasons behind this action, and feel free to browse and use the forums.
    You might find answers to your questions in one of these forums:
    http://forum.allaboutcircuits.com/showthread.php?t=54400
    Another good forum that shares many of the same membership is http://www.electro-tech-online.com/ . Good luck.
    Dr.killjoy likes this.
Thread Status:
