autotransfomer vs tapped coil in a hartley oscillator
Discussion in 'General Electronics Chat' started by leonheard, Dec 3, 2014.
  1. leonheard
    Jan 8, 2013
    48
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I guess the difference is the basis for using a tapped inductor in the Hartley oscillator.
    The goal is to achieve the required phase shift in the oscillator feedback path so that oscillation can actually take place.
    The Hartley has a dual topology in the Colpitts oscillator where the phase shift is achieved using a pair of capacitors ("tapped" at a common reference point) in the main tuning network.
    This perhaps begs the question...
    Would the Hartley work just as well using two magnetically uncoupled inductors, rather than the single element "auto transformer" / tapped inductor topology?
    Give it some thought ....
  3. Charles Wenzel
    Dec 2, 2014
    10
    In the Hartley oscillator the center-tap is held at AC ground (typically) so one end swings in the opposite direction from the other, like a seesaw, providing the phase inversion needed for oscillation. The autotransformer typically has one end grounded and the tap swings in the same direction (same polarity) as the voltage across the entire coil (more like a pry bar).
  4. ErnieM
    Apr 24, 2011
    7,434
    1,625
    They are very similar and completely different.
    Similar in that they are both taped inductors.
    Different in one is for very small signals and the other for AC power.
    They do both work on the same set of equations.
    GopherT likes this.
  5. leonheard
    Jan 8, 2013
    48
    wow! amazing how complex a coil and capacitor are, they can behave in many different ways .
    I would like to study and have a DEEP understanding in this subject. So I would know in the future for example why the tapped coil in a Hartley oscillator is sometimes connected to ground and in other circuit they are connected to power supply. What book/web page you recommend? mathematics is not a big problem for me.
    hartley tapped coil connected to ground:
    http://www.electronics-tutorials.ws/oscillator/osc6.gif
    hartley tapped coil connected to power supply
    http://www.learnabout-electronics.org/Oscillators/images/hartley-oscillator-c-e.gif
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    One of the most important concepts in signal analysis is that the effectively decoupled DC power supply ac potential is equivalent to signal ground.
    However, it is not a fundamental requirement that the tap point be ac or signal grounded for the Hartley oscillator to function. Other topologies are possible.
  7. leonheard
    Jan 8, 2013
    48
    Superposition theorem?
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    That's too cryptic for me. What do you mean?
  9. leonheard
    Jan 8, 2013
    48
    I mean, in ac analysis you use the superposition theorem, is that correct?
