Automotive Warning Light
Discussion in 'The Projects Forum' started by renniweht03, Mar 25, 2011.
  1. renniweht03
    Mar 25, 2011
    Hey Everyone!
    Im doing a project on my car which requires the use of an electric oil pump. The pump has a fuse inline and is turned on with a relay. 12v will be used. I want to make a warning circuit so that if the fuse blows for the electric pump I will be notified by either a buzzer or a light turning on. It sounds really simple to me but I can not figure this one out. Any help I would really appreciate! Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We are iffy about cars and modifications. Could you say what the oil pump's function is?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Won't the oil pressure light that is already there give you a warning?
    John
  4. renniweht03
    Mar 25, 2011
    The pump is for a rear mounted turbocharger setup. It is a scavenge pump that when the oil comes out of the turbocharger this electric pump pushes it back up to the engine.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Consider just using a small 12v bulb connected across the fuse.
    If the fuse blows, the bulb will light up.
  6. debe
    Sep 21, 2010
    955
    185
    Personaly I would use an Audio type indicator eg buzzer, lights tend to be missed in a vehicle. Generaly Ive found engines destroyed from lack of oil pressure due to the warning light beeing missed in daylight. Lack of oil dammage is fairly quick. Sgt Wookies idea across the fuse is the easiest way of doing it.
  7. renniweht03
    Mar 25, 2011
    Thank you for your responses. I will do some experimenting with this idea and let you know how it goes.
  8. shortbus
    Sep 30, 2009
    4,096
    1,692
    Thought it might be for a James Bond oil slick device ;)
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Maybe on Hugo's.
