Remote start alarm systems for cars have the option to use voltage sensing to tell the alarm when the vehicle is actually running to it knows to stop cranking the starter. does anyone know exactly how this technology works and if there is a circuit i can create that will do the same thing and provide me with a negative output to drive a relay that will remain constant until it detects that the motor is no longer running (not just turning off the ignition but say the vehicle stalls it will cut the ground output)
Before the voltage sensing you had to connect a wire to the tach signal. i imagine this would be a simpler circuit. i'm curious as to how this style works as well and how i could connect to the tach signal to trigger a constant ground output as long as the motor is running and shuts off when the motor stops.
