Automotive Accessory Socket
Discussion in 'General Electronics Chat' started by tom66, Aug 22, 2011.
  1. tom66
    Thread Starter Senior Member
    May 9, 2009
    2,613
    214
    I hope this does not come under the Automotive Guidelines.
    I want to plug a device into a cigarette lighter socket / automotive accessory socket. Using a 12V (nom.) car and the device is rated from 10V - 18V and it draws at most 3 amps. It's a battery charger for LiPo batteries.
    I already have a connector for the socket, with a built in 15A fuse. However, the battery voltage is barely a fixed 11V - 14.4V. It can have high voltage spikes on it and brief undervoltage moments. Both of these would potentially damage or interrupt the device. So I want to protect against them.
    What are my options?
    I was thinking of a TVS device rated at 16V with a pi filter to reduce ripple and another TVS on the output. The capacitors would be sized for a 50ms dead time, providing sufficient power to the charger during brief under voltage. A 5A auto fuse would also be used and an LED might be used to indicate power.
  2. gotumal
    Mar 24, 2008
    99
    Yes, you are right. a TVS at input and LC filter would do. You don"t need a TVS at output, since output capacitor sees a inductor to charge. Be sure about the energy of the pulses that you are expecting at line. Also a reverse polarity protection, otherwise TVS would blow!
