I had thought of that, as well, but I wasn't sure if it would be powerful enough. What are the specifications of a radiator fan motor?A large radiator fan motor would be a better propositon than the starter motor or alternator .
That's going to depend on the model of car. The radiator fan motor in my nissan sentra is about the same size as a cordless drill motor.I had thought of that, as well, but I wasn't sure if it would be powerful enough. What are the specifications of a radiator fan motor?
I have various cordless drill motors, but none of them are powerful enough. I also read once about someone who used two cordless drills to power the two rear wheels of a go-cart, but they were 36v drills, which are very expensive (for me )That's going to depend on the model of car. The radiator fan motor in my nissan sentra is about the same size as a cordless drill motor.
thats an idea.
I have seen a cordless drill used before to drive a razor scooter; 2 of them might power a bike nicely - or not
This is a good suggestion. I will be using a microcontroller for the PWM anyway, so I may be able to use part of it for a speed detector. I will definitely look into it!Man I have been thinking about this and I think the simplest way would be to use your starter motor and PWM. Just put a low value power resistor in series with the starter. Figure that the starter will be almost a direct short at zero speed so use a 1Ω resistor for a 12A limit or a 2Ω for 6A limit and so on. If you find that it doesn't have enough balls, then add an encoder or something for speed detection, connected to a μC (or other circuit) and once it's at speed, have a relay short out the current limiting resistor.
Wow, that second one is almost exactly what I would like to do! The only difference is that I would still like to be able to pedal the bike sometimes. Also, I can't seem to figure out where they put the batteries, and what type they were...?I love this kind of ideas. I have a retired go-kart sitting at the back of my house which I hope to eventually convert to electric. I plan on using motors and drives from "real" EV parts though, but I certainly have googled starter motor options for projects earlier:
Go-kart
http://www.youtube.com/watch?v=C5lp3fP1WKo
Bike
http://www.youtube.com/watch?v=x8cJ1GNiHOI
Looks like lots of fun!
Have you seen this? http://www.ecospeed.com/emddet.html May give some ideas as to doing what you want to keep the pedals.Wow, that second one is almost exactly what I would like to do! The only difference is that I would still like to be able to pedal the bike sometimes. Also, I can't seem to figure out where they put the batteries, and what type they were...?
EDIT: Well guys, I'm thinking of just taking off the pedals of my bike to make room for other parts. I guess I'll be powering it just by motor. Otherwise, I wouldn't have room for anything else. Just thought I'd let you all know
Yikes, I guess I should look into the laws in my state. I never thought of that...oops! I think you'd better keep those pedals on. Once you remove the pedals that contraption falls under the classification of a motorcycle, with all the registration, licensing and insurance requirements.
I see nothing about the absence of pedals written here, so I think I'm okay. I will keep looking though, just to make sure.[The bill] States that, for purposes of Federal motor vehicle safety standards, a low-speed electric bicycle as defined by CPSA shall not be considered to be a motor vehicle within the ambit of Federal transportation law.
2/27/2001 Introduced in House
3/5/2001 Reported by the Committee on Energy and Commerce. H. Rept. 107-5.
3/6/2001 Passed/agreed to in House: On motion to suspend the rules and pass the bill Agreed to by the Yeas and Nays: (2/3 required): 401 - 1 (Roll no. 27).
11/18/2002 Senate Committee on Commerce, Science, and Transportation discharged by Unanimous Consent.
11/18/2002 Passed/agreed to in Senate: Passed Senate without amendment by Unanimous Consent.
11/18/2002 Cleared for White House.
11/22/2002 Presented to President.
12/4/2002 Signed by President.
12/4/2002 Became Public Law No: 107-319
So, Mr. Chips, You are right, and I can't make "dummy pedals" like I suggested. I guess I'll have to work out some other way of setting this up. Thank you very much for mentioning this--I could have gotten in a lot of troubleCPSC rules stipulate that low speed electric bicycles[24] (to include two and three wheel vehicles) are exempt from classification as motor vehicles providing they have fully operable pedals, an electric motor of less than 750W (1 hp), and a top motor-powered speed of less than 20 miles per hour (32 km/h) when operated by a rider weighing 170 pounds.
I had an old 12 volt weed whacker and I took the motor out of it. Unfortunately, it's really small and would not even begin to move the bike. I can hold onto the shaft and it wouldn't move!Since you can't control the torque on a starter motor as mentioned earlier, can you get your hands on a weed whacker or chain saw motor? I think a strong blender motor might even be of use...
I'm curious to see how this turns out
I suppose you did not get a chance to read all four pages of this thread? This idea that you mentioned is something that is being discussed. I have seen several videos of bicycles with starter motors on youtube. I think it will be fine for what I plan to use it for.Starter motors are designed for intermittent duty and very high torque at very low speed and, while they could probably be useable for an electric bike, would be far from optimum.
You can buy motors specifically designed for electric bikes and go-carts at salvage or surplus stores. I think they sell in the $30 or so range. Two sources where I have seen many of these motors are All Electronics in Van Nuys, CA (888-826-5432, www.allelectronics.com) or Apex Surplus Electronics in Sun Valley, CA (818-767-7202, www.apexelectronic.com). Shipping should not be too much because these motors are only a few pounds, but you may find some at surplus electronics outlets closer to VT. All Electronics also carried some simple electronic controllers just for these motors at one time. The motors I've seen come in two power ratings, but I don't remember what the ratings were.
awright
there's a reason they don't make locking hubcaps on 4X4 trucks anymore. they're not as convenient as they seemWell, guys, I had another idea. Instead of going without pedals, I thought of another way to have both. The pedals are easily removable on my bike, so I am thinking of just taking off the pedals when I want to use the motor. Then, when I want to pedal, I can just put them back on. Easy, right? Any opinions or suggestions?
Thanks!
Der Strom
Um... Are you agreeing or disagreeing with my idea?there's a reason they don't make locking hubcaps on 4X4 trucks anymore. they're not as convenient as they seem
