Automobile DC Generator
Discussion in 'General Electronics Chat' started by hennesse, Nov 28, 2010.
  1. hennesse
    Nov 28, 2010
    I have an antique motorcycle that's supposed to have a fuse in the Field wire between the "voltage regulator" and the generator. The voltage regulator does not include a current regulator like most old cars do, so the fuse is important in case of a short circuit somewhere.
    What size fuse? Well, when I get the engine running, I can hook an ammeter in the Field wire. Until then...
    I'm wondering if there's a general ratio between a DC generator's output (in this case 6 amps), and the current carried by the field coils.
    Dave Hennessey
  2. tom66
    May 9, 2009
    Probably the simplest method is to insert increasing values of fuses until the fuses stop blowing ;). I think automotive fuses only come a few ratings so you won't have to go through many, and they are dirt cheap anyway.
