Automatic water dispenser
Discussion in 'The Projects Forum' started by n0nesense, Jan 23, 2013.
  1. n0nesense
    Jan 11, 2013
    8
    I am doing an automatic water dispenser system for my mini project. I have found the circuit online, but the circuit dont have the types of diode and transistor used.
    I have tried to contact the owner of the circuit, but he/she has failed to respond.
    I would appreciate if you can suggest what type of diode and transistor i should use to make the circuit work.
    This is how it should work : http://www.youtube.com/watch?v=RPrjL4HU640
    I tried using transistor TIP122 and diode 1N4001, but the motor wont stop when i removed the light from the second LDR (The lower LDR in circuit)
    Thank you for reading and please help me!
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Draw a circuit diagram of your circuit.
  3. n0nesense
    Jan 11, 2013
    8
    i have included the circuit diagram in the first post. The first picture is the operation, one by one. The second picture is the circuit.
  4. n0nesense
    Jan 11, 2013
    8
    NOTICE: The problem is solved! Thank you!
  5. tshuck
    Oct 18, 2012
    3,531
    675
    Perhaps you could post what the solution was in order to help people finding this thread in the future...
