The LM311 electronic version is a simple circuit, the reason that it was replaced in automobiles is due to the the radio interference caused and inline suppressors were needed for the radio.Wat i need is the electronic type. Thanks
Aha, that makes for the "automatic" part. I supose that then, the regulator part will make the "steps" not evident.on power ines, their called tap changers. an electromechanical switch to change taps on transformers. does it automatically too.
by Aaron Carman
by Aaron Carman
by Jake Hertz
